Membership Inference Attacks on Aggregated Time Series with Linear Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Antonin Voyez
  • Fonction : Auteur
  • PersonId : 1069511
Tristan Allard
Gildas Avoine
  • Fonction : Auteur
Pierre Cauchois
  • Fonction : Auteur
  • PersonId : 1006847
Aggregating data is a widely used technique to protect privacy. Membership inference attacks on aggregated data aim to infer whether a specific target belongs to a given aggregate. We propose to study how aggregated time series data can be susceptible to simple membership inference privacy attacks in the presence of adversarial background knowledge. We design a linear programming attack that strongly benefits from the number of data points published in the series and show on multiple public datasets how vulnerable the published data can be if the size of the aggregated data is not carefully balanced with the published time series length. We perform an extensive experimental evaluation of the attack on multiple publicly available datasets. We show the vulnerability of aggregates made of thousands of time series when the aggregate length is not carefully balanced with the published length of the time series.
article_ksa_secrypt.pdf (448.87 Ko) Télécharger le fichier
hal-03726234 , version 1 (18-07-2022)
Antonin Voyez, Tristan Allard, Gildas Avoine, Pierre Cauchois, Elisa Fromont, et al.. Membership Inference Attacks on Aggregated Time Series with Linear Programming. SECRYPT 2022 - 19th International Conference on Security and Cryptography, Jul 2022, Lisbon, France. pp.193-204, ⟨10.5220/0011276100003283⟩. ⟨hal-03726234⟩
146 Consultations
156 Téléchargements
