Towards a Model-Based Serverless Platform for the Cloud-Edge-IoT Continuum - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
One of the most prominent implementations of the serverless programming model is Function-as-a-Service (FaaS). Using FaaS, application developers provide source code of serverless functions, typically describing only parts of a larger application, and define triggers for executing these functions on infrastructure components managed by the FaaS provider. There are still challenges that hinder the wider adoption of the FaaS model across the whole Cloud-Edge-IoT continuum. These include the high heterogeneity of the Edge and IoT infrastructure, vendor lock-in, the need to deploy and adapt serverless functions as well as their supporting services and software stacks into their cyber-physical execution environment. As a first step towards addressing these challenges, we introduce the \siot platform for the design, deployment, and maintenance of applications over the Cloud-Edge-IoT continuum. In particular, our platform enables the specification and deployment of serverless functions on Cloud and Edge resources, as well as the deployment of their supporting services and software stacks over the whole Cloud-Edge-IoT continuum.
Serverless4IoT-19.pdf (1.54 Mo) Télécharger le fichier
hal-03729308 , version 1 (03-01-2023)
Nicolas Ferry, Rustem Dautov, Hui Song. Towards a Model-Based Serverless Platform for the Cloud-Edge-IoT Continuum. CCGrid 2022 - 22nd IEEE/ACM International Symposium on Cluster Computing and the Grid : Workshop on Cloud-to-Things continuum: towards the convergence of IoT, Edge and Cloud Computing, May 2022, Taormina, Italy. pp.851-858, ⟨10.1109/CCGrid54584.2022.00101⟩. ⟨hal-03729308⟩
43 Consultations
78 Téléchargements
