Semidefinite programming lower bounds on the squashed entanglement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
The squashed entanglement is a widely used entanglement measure that has many desirable properties. However, as it is based on an optimization over extensions of arbitrary dimension, one drawback of this measure is the lack of good algorithms to compute it. Here, we introduce a hierarchy of semidefinite programming lower bounds on the squashed entanglement.
hal-03750963 , version 1 (13-08-2022)
Paternité
Hamza Fawzi, Omar Fawzi. Semidefinite programming lower bounds on the squashed entanglement. 2022. ⟨hal-03750963⟩
52 Consultations
0 Téléchargements
