EMG-Based Automatic Gesture Recognition Using Lipschitz-Regularized Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Intelligent Systems and Technology Année : 2023
This paper introduces a novel approach for building a robust Automatic Gesture Recognition system based on Surface Electromyographic (sEMG) signals, acquired at the forearm level. Our main contribution is to propose new constrained learning strategies that ensure robustness against adversarial perturbations by controlling the Lipschitz constant of the classifier. We focus on positive neural networks for which accurate Lipschitz bounds can be derived, and we propose different spectral norm constraints offering robustness guarantees from a theoretical viewpoint. Experimental results on two distinct datasets highlight that a good trade-off in terms of accuracy and performance is achieved. We then demonstrate the robustness of our models, compared to standard trained classifiers in three scenarios, considering both white-box and black-box attacks.
HAL_extended_version.pdf (2.01 Mo) Télécharger le fichier
hal-03751766 , version 1 (16-08-2022)
hal-03751766 , version 2 (17-02-2023)
  • HAL Id : hal-03751766 , version 2
Jean-Christophe Pesquet, Corneliu Burileanu, Ana-Antonia Neacșu. EMG-Based Automatic Gesture Recognition Using Lipschitz-Regularized Neural Networks. ACM Transactions on Intelligent Systems and Technology, 2023. ⟨hal-03751766v2⟩
196 Consultations
130 Téléchargements
