Factoring differential operators over algebraic curves in positive characteristic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present an algorithm for factoring linear differential operators with coefficients in a finite separable extension of F p (x). Our methods rely on specific tools arising in positive characteristic: p-curvature, structure of simple central algebras and p-Riccati equations.
ACM_extended_abstract.pdf (92.29 Ko) Télécharger le fichier
hal-03759105 , version 1 (23-08-2022)
  • HAL Id : hal-03759105 , version 1
Raphaël Pagès. Factoring differential operators over algebraic curves in positive characteristic. ISSAC 2022 - International Symposium on Symbolic and Algebraic Computation, Jul 2022, Lille, France. ⟨hal-03759105⟩
87 Consultations
26 Téléchargements
