Leveraging Web browsing performance data for network monitoring: a data-driven approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Monitoring network performance becomes crucial today since it allows content providers to ensure a good quality of their services by identifying the root causes of service degradation. Also, it gives the end-user a better understanding of the performance they have (state of the networks). A widely used monitoring technique involves performing measurements from within the browser in an effort to capture the network status as close as possible; we talk about Web-based network monitoring. Many Web measurement tools have recently been proposed, however, most of these tools either have a high computational cost or exaggeratedly consume data. In this paper, we propose a lightweight solution able to estimate the underlying network status accurately and perform Web troubleshooting in order to detect anomalies. We develop and implement a distributed system that collects measurements at both levels: browser and network. Then, we build an original network monitoring framework based on Bayesian Gaussian Mixture Models (BGMM) coupled with an algorithm to detect in real time the occurrence of anomalies. We follow a browser-based passive measurement and data-driven approach to derive our inference models, which leads to an efficient Web browsing troubleshooting solution.
IEEE_Globecom_2022.pdf (416.37 Ko) Télécharger le fichier
hal-03763839 , version 1 (29-08-2022)
Imane Taibi, Yassine Hadjadj-Aoul, Chadi Barakat. Leveraging Web browsing performance data for network monitoring: a data-driven approach. GLOBECOM 2022 - IEEE Global Communications Conference, Dec 2022, Rio de Janeiro / Hybrid, Brazil. pp.1-6, ⟨10.1109/GLOBECOM48099.2022.10001139⟩. ⟨hal-03763839⟩
121 Consultations
82 Téléchargements
