Impact of Injecting Ground Truth Explanations on Relational Graph Convolutional Networks and their Explanation Methods for Link Prediction on Knowledge Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Relational Graph Convolutional Networks (RGCNs) are commonly applied to Knowledge Graphs (KGs) for black box link prediction. Several algorithms, or explanations methods, have been proposed to explain the predictions of this model. Recently, researchers have constructed datasets with ground truth explanations for quantitative and qualitative evaluation of predicted explanations. Benchmark results showed state-of-theart explanation methods had difficulties predicting explanations. In this work, we leverage prior knowledge to further constrain the loss function of RGCNs, by penalizing node embeddings far away from the node embeddings in their associated ground truth explanation. Empirical results show improved explanation prediction performance of state-of-the-art post hoc explanations methods for RGCNs, at the cost of predictive performance. Additionally, we quantify the different types of errors made both in terms of data and semantics.
WI_2022.pdf (249.51 Ko) Télécharger le fichier
hal-03771424 , version 1 (07-09-2022)
  • HAL Id : hal-03771424 , version 1
Nicholas Halliwell, Fabien Gandon, Freddy Lecue. Impact of Injecting Ground Truth Explanations on Relational Graph Convolutional Networks and their Explanation Methods for Link Prediction on Knowledge Graphs. WI-IAT 2022 - The 21st IEEE/WIC/ACM International Conference on Web Intelligence and Intelligent Agent Technology, Nov 2022, Niagara Falls / Hybrid, Canada. ⟨hal-03771424⟩
110 Consultations
112 Téléchargements
