Errors in the CICIDS2017 dataset and the significant differences in detection performances it makes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Among the difficulties encountered in building datasets to evaluate intrusion detection tools, a tricky part is the process of labelling the events into malicious and benign classes. The labelling correctness is paramount for the quality of the evaluation of intrusion detection systems but is often considered as the ground truth by practitioners and is rarely verified. Another difficulty lies in the correct capture of the network packets. If it is not the case, the characteristics of the network flows generated from the capture could be modified and lead to false results. In this paper, we present several flaws we identified in the labelling of the CICIDS2017 dataset and in the traffic capture, such as packet misorder, packet duplication and attack that were performed but not correctly labelled. Finally, we assess the impact of these different corrections on the evaluation of supervised intrusion detection approaches.
CRiSIS_2022_Maxime_Lanvin.pdf (700.84 Ko) Télécharger le fichier
hal-03775466 , version 1 (12-09-2022)
Paternité
Maxime Lanvin, Pierre-François Gimenez, Yufei Han, Frédéric Majorczyk, Ludovic Mé, et al.. Errors in the CICIDS2017 dataset and the significant differences in detection performances it makes. 17th International Conference on Risks and Security of Internet and Systems (CRiSIS), Dec 2022, Sousse, Tunisia. pp.18-33, ⟨10.1007/978-3-031-31108-6_2⟩. ⟨hal-03775466⟩
717 Consultations
1181 Téléchargements
