LIPS - Learning Industrial Physical Simulation benchmark suite - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Milad Leyli-Abadi
David Danan
Mouadh Yagoubi
  • Fonction : Auteur
  • PersonId : 1054942
Seif-Eddine Attoui
  • Fonction : Auteur
  • PersonId : 1114614
Antoine Marot
  • Fonction : Auteur
  • PersonId : 1079813
P Dimitrov
  • Fonction : Auteur
C Etienam
  • Fonction : Auteur
A Farjallah
  • Fonction : Auteur
Physical simulations are at the core of many critical industrial systems. However, today's physical simulators have some limitations such as computation time, dealing with missing or uncertain data, or even non-convergence for some feasible cases. Recently, the use of data-driven approaches to learn complex physical simulations has been considered as a promising approach to address those issues. However, this comes often at the cost of some accuracy which may hinder the industrial use. To drive this new research topic towards a better real-world applicability, we propose a new benchmark suite "Learning Industrial Physical Simulations"(LIPS) to meet the need of developing efficient, industrial application-oriented, augmented simulators. To define how to assess such benchmark performance, we propose a set of four generic categories of criteria. The proposed benchmark suite is a modular and configurable framework that can deal with different physical problems. To demonstrate this ability, we propose in this paper to investigate two distinct use-cases with different physical simulations, namely: the power grid and the pneumatic. For each use case, several benchmarks are described and assessed with existing models. None of the models perform well under all expected criteria, inviting the community to develop new industry-applicable solutions and possibly showcase their performance publicly upon online LIPS instance on Codabench.
lips_learning_industrial_physi.pdf (749.59 Ko) Télécharger le fichier
hal-03780816 , version 1 (19-09-2022)
  • HAL Id : hal-03780816 , version 1
Milad Leyli-Abadi, David Danan, Mouadh Yagoubi, Seif-Eddine Attoui, Antoine Marot, et al.. LIPS - Learning Industrial Physical Simulation benchmark suite. NeurIPS - Data & Benchmark Track, Nov 2022, New Orleans, United States. ⟨hal-03780816⟩
Collections
IRT-SYSTEMX
301 Consultations
75 Téléchargements
