Dynamic modeling of global fossil fuel infrastructure and materials needs: Overcoming a lack of available data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Energy Année : 2022
The low-carbon energy transition requires a widespread change in global energy infrastructures which in turn calls for important inputs of energy and materials. While the transport and electricity sectors have been thoroughly analyzed in this regard, that of the hydrocarbon industry has not received the same attention, maybe in part due to the difficulty of access to the necessary data. To fill this gap, we assemble public-domain data from a wide variety of sources to present a stock-flow dynamic model of the fossil fuels supply chain. It is conducted from 1950 to 2050 and along scenarios from the International Energy Agency. We estimate the concrete, steel, aluminum and copper requirements for each segment, as well as the embedded energy and CO2 emissions through a dynamic material flow analysis (MFA) model. We find that (i) the material intensities of oil, gas and coal supply chains have stagnated for more than 30 years; (ii) gas is the main driver of current and future material consumption; and (iii) recycled steel from decommissioned fossil fuels infrastructures could meet the cumulative need of future low-carbon technologies and reduce its energy and environmental toll. Furthermore, we highlight that regional decommissioning strategies significantly affect the potential of material recycling and reuse. In this context, ambitious decommissioning strategies could drive a symbolic move to build future renewable technologies from past fossil fuel structures.
Dynamic modeling of global fossil fuel infrastructure and materials needs.pdf (931.8 Ko) Télécharger le fichier
SI - Dynamic modeling of global fossil fuel infrastructure and materials needs.pdf (1.41 Mo) Télécharger le fichier
SI - Dynamic modeling of global fossil fuel infrastructure and materials needs.xlsx (167.68 Ko) Télécharger le fichier
hal-03780879 , version 1 (19-09-2022)
Hugo Le Boulzec, Louis Delannoy, Baptiste Andrieu, François Verzier, Olivier Vidal, et al.. Dynamic modeling of global fossil fuel infrastructure and materials needs: Overcoming a lack of available data. Applied Energy, 2022, 326, ⟨10.1016/j.apenergy.2022.119871⟩. ⟨hal-03780879⟩
186 Consultations
201 Téléchargements
