Characterizing Prefetchers using CacheObserver - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hardware prefetchers are mostly undocumented micro-architectural components of the cache hierarchy, with performance and security implications. Intel CPUs feature four named prefetchers whose behaviors are generally unknown. We build CacheObserver, a generic framework to study prefetchers on Intel CPUs and the first to use the Flush+Flush primitive, unlike previous studies using Flush+Reload. We apply this framework to characterize the L2 Stream prefetcher on the Intel Whiskey and Coffee Lake micro-architectures and uncover the behavior of the L2 Stream prefetcher upon the first few accesses in a page. We also uncover interactions at the L2 level between the Stream and the Adjacent Cache Line prefetchers.
sbac-pad22_didier.pdf (3.09 Mo) Télécharger le fichier
hal-03798500 , version 1 (05-10-2022)
  • HAL Id : hal-03798500 , version 1
Guillaume Didier, Clémentine Maurice, Antoine Geimer, Walid J Ghandour. Characterizing Prefetchers using CacheObserver. IEEE 34th International Symposium on Computer Architecture and High Performance Computing, Nov 2022, Bordeaux, France. ⟨hal-03798500⟩
92 Consultations
323 Téléchargements
