Active Labeling: Streaming Stochastic Gradients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The workhorse of machine learning is stochastic gradient descent. To access stochastic gradients, it is common to consider iteratively input/output pairs of a training dataset. Interestingly, it appears that one does not need full supervision to access stochastic gradients, which is the main motivation of this paper. After formalizing the "active labeling" problem, which focuses on active learning with partial supervision, we provide a streaming technique that provably minimizes the ratio of generalization error over the number of samples. We illustrate our technique in depth for robust regression.
Active_labeling__SGD.pdf (2.74 Mo) Télécharger le fichier
hal-03806666 , version 1 (07-10-2022)
  • HAL Id : hal-03806666 , version 1
Vivien Cabannes, Francis S Bach, Vianney Perchet, Alessandro Rudi. Active Labeling: Streaming Stochastic Gradients. NeurIPS 2022 - 36th Conference on Neural Information Processing Systems, Nov 2022, New Orleans, United States. ⟨hal-03806666⟩
78 Consultations
43 Téléchargements
