Tabular and Deep Learning of Whittle Index - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2022
- Whittle index policy is an asymptotically optimal heuristic for solving Restless Multi-Armed Bandit Problems (RMBAP). - We propose two algorithms, QWI and QWINN, for the computation of such indices. - Both employ a two timescale system for the computation of the indices and the Q-values of each state/action.
poster.pdf (2.63 Mo) Télécharger le fichier
hal-03810695 , version 1 (11-10-2022)
  • HAL Id : hal-03810695 , version 1
Francisco Robledo, Urtzi Ayesta, Konstantin Avrachenkov, Vivek S Borkar. Tabular and Deep Learning of Whittle Index. EWRL 2022 - 15th European Workshop on Reinforcement Learning, Sep 2022, Milan, Italy. ⟨hal-03810695⟩
54 Consultations
43 Téléchargements
