Consistent discretization of a homogeneous finite-time control for a double integrator
A discretization of a homogeneous controller for a double integrator is developed. It preserves the finite-time stability property even in the case of the sampled-time implementation of the control law. Theoretical results are supported by numerical simulations.
Automatique
