Incrementally semi-supervised classification of arthritis inflammation on a clinical dataset - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
For best medical imaging application results, learning-based approaches such as deep learning necessitate specific, extensive and precise annotations. Outside well-curated public benchmarks, these are rarely available in practice, and so it becomes necessary to use less-than-perfect annotations. One way of compensating for this is the embedding of anatomical knowledge. Complementing this, there is the incremental semi-supervised learning technique, whereby a small amount of annotations can be used to derive more and superior labels.In this article, we illustrate this approach on a deep learning system to help radiologists and rheumatologists finely and interactively assess MRI scans of the sacro-iliac joint in order to correctly diagnose Axial Spondyloarthritis. Our model is trained initially on a relatively small set of images with promising results, on par with expert opinion and generalizable to new datasets.
Spondylarthrite_ICIP_2022.pdf (764.19 Ko) Télécharger le fichier
hal-03830567 , version 1 (26-10-2022)
  • HAL Id : hal-03830567 , version 1
Théodore Aouad, Clementina Lopez-Medina, Charlotte Martin-Peltier, Adrien Bordner, Sisi Yang, et al.. Incrementally semi-supervised classification of arthritis inflammation on a clinical dataset. IEEE International Conference on Image Processing 2022, IEEE, Oct 2022, Bordeaux, France. ⟨hal-03830567⟩
92 Consultations
60 Téléchargements
