Text-Free Prosody-Aware Generative Spoken Language Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Speech pre-training has primarily demonstrated efficacy on classification tasks, while its capability of generating novel speech, similar to how GPT-2 can generate coherent paragraphs, has barely been explored. Generative Spoken Language Modeling (GSLM) (Lakhotia et al., 2021) is the only prior work addressing the generative aspects of speech pretraining, which replaces text with discovered phone-like units for language modeling and shows the ability to generate meaningful novel sentences. Unfortunately, despite eliminating the need of text, the units used in GSLM discard most of the prosodic information. Hence, GSLM fails to leverage prosody for better comprehension, and does not generate expressive speech. In this work, we present a prosody-aware generative spoken language model (pGSLM). It is composed of a multi-stream transformer language model (MS-TLM) of speech, represented as discovered unit and prosodic feature streams, and an adapted HiFi-GAN model converting MS-TLM outputs to waveforms. We devise a series of metrics for prosody modeling and generation, and re-use metrics from GSLM for content modeling. Experimental results show that the pGSLM can utilize prosody to improve both prosody and content modeling, and also generate natural, meaningful, and coherent speech given a spoken prompt. 1
_ARR_21__Prosody_Aware_Generative_Spoken_Language_Modeling.pdf (769.67 Ko) Télécharger le fichier
hal-03831818 , version 1 (09-01-2023)
  • HAL Id : hal-03831818 , version 1
Eugene Kharitonov, Ann Lee, Adam Polyak, Yossi Adi, Jade Copet, et al.. Text-Free Prosody-Aware Generative Spoken Language Modeling. ACL 2022 - Association for Computational Linguistics, May 2022, Dublin, Ireland. pp.8666-8681. ⟨hal-03831818⟩
34 Consultations
44 Téléchargements
