Stationary brownian motion in a 3/4-plane: Reduction to a riemann-hilbert problem via fourier transforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Indagationes Mathematicae Année : 2023
The stationary reflected Brownian motion in a three-quarter plane has been rarely analyzed in the probabilistic literature, in comparison with the quarter plane analogue model. In this context, our main result is to prove that the stationary distribution can indeed be found by solving a boundary value problem of the same kind as the one encountered in the quarter plane, up to various dualities and symmetries. The main idea is to start from Fourier (and not Laplace) transforms, allowing to get a functional equation for a single function of two complex variables.
indag891.pdf (720.41 Ko) Télécharger le fichier
hal-03832431 , version 1 (27-10-2022)
hal-03832431 , version 2 (12-11-2022)
Paternité
Guy Fayolle, Sandro Franceschi, Kilian Raschel. Stationary brownian motion in a 3/4-plane: Reduction to a riemann-hilbert problem via fourier transforms. Indagationes Mathematicae, 2023, 34 (5), pp.17 (874-890). ⟨10.1016/j.indag.2022.10.008⟩. ⟨hal-03832431v2⟩
122 Consultations
43 Téléchargements
