Semi-relaxed Gromov Wasserstein divergence with applications on graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Comparing structured objects such as graphs is a fundamental operation involved in many learning tasks. To this end, the Gromov-Wasserstein (GW) distance, based on Optimal Transport (OT), has proven to be successful in handling the specific nature of the associated objects. More specifically, through the nodes connectivity relations, GW operates on graphs, seen as probability measures over specific spaces. At the core of OT is the idea of conservation of mass, which imposes a coupling between all the nodes from the two considered graphs. We argue in this paper that this property can be detrimental for tasks such as graph dictionary or partition learning, and we relax it by proposing a new semi-relaxed Gromov-Wasserstein divergence. Aside from immediate computational benefits, we discuss its properties, and show that it can lead to an efficient graph dictionary learning algorithm. We empirically demonstrate its relevance for complex tasks on graphs such as partitioning, clustering and completion.
hal-03832589 , version 1 (27-10-2022)
Cédric Vincent-Cuaz, Rémi Flamary, Marco Corneli, Titouan Vayer, Nicolas Courty. Semi-relaxed Gromov Wasserstein divergence with applications on graphs. ICLR 2022 - 10th International Conference on Learning Representations, Apr 2022, Virtual, France. pp.1-28. ⟨hal-03832589⟩
88 Consultations
0 Téléchargements
