Wind Turbine Quantification and Reduction of Uncertainties Based on a Data-Driven Data Assimilation Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Renewable and Sustainable Energy Année : 2022
In this paper, we propose a procedure for quantifying and reducing uncertainties that impact numerical simulations involved in the estimation of the fatigue of a wind turbine structure. The present study generalizes a previous work carried out by the authors proposing to quantify and to reduce uncertainties that affect the properties of a wind turbine model by combining a global sensitivity analysis and a recursive Bayesian filtering approach. We extend the procedure to include the uncertainties involved in the modeling of a synthetic wind field. Unlike the model properties having a static or slow time-variant behavior, the parameters related to the external solicitation have a non-explicit dynamic behavior, which must be taken into account during the recursive inference. A non-parametric data-driven approach to approximate the non-explicit dynamic of the inflow related parameters is used. More precisely, we focus on data assimilation methods combining a nearest neighbor or an analog sampler with a stochastic filtering method such as the ensemble Kalman filter. The so-called data-driven data assimilation approach is used to recursively reduce the uncertainties that affect the parameters related to both model properties and wind field. For the approximation of the non-explicit dynamic of the wind inflow related parameters, in situ observations obtained from a light detection and ranging system and a cup-anemometer device are used. For the data-assimilation procedure, synthetic data simulated from the aero-servo-elastic numerical model are considered. The next investigations will be to verify the procedure with real in situ data.
Wind Turbine Quantification and Reduction of Uncertainties Based on a Data-Driven Data Assimilation Approach.pdf (711.5 Ko) Télécharger le fichier
hal-03855143 , version 1 (21-12-2021)
hal-03855143 , version 2 (16-11-2022)
Paternité
Adrien Hirvoas, Clémentine Prieur, Élise Arnaud, Fabien Caleyron, Miguel Munoz Zuniga. Wind Turbine Quantification and Reduction of Uncertainties Based on a Data-Driven Data Assimilation Approach. Journal of Renewable and Sustainable Energy, 2022, 14 (5), pp.053303. ⟨10.1063/5.0086255⟩. ⟨hal-03855143v2⟩
164 Consultations
195 Téléchargements
