Bayesian mixture models (in)consistency for the number of clusters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2023
Bayesian nonparametric mixture models are common for modeling complex data. While these models are well-suited for density estimation, their application for clustering has some limitations. Recent results proved posterior inconsistency of the number of clusters when the true number of clusters is finite for the Dirichlet process and Pitman--Yor process mixture models. We extend these results to additional Bayesian nonparametric priors such as Gibbs-type processes and finite-dimensional representations thereof. The latter include the Dirichlet multinomial process, the recently proposed Pitman--Yor, and normalized generalized gamma multinomial processes. We show that mixture models based on these processes are also inconsistent in the number of clusters and discuss possible solutions. Notably, we show that a post-processing algorithm introduced for the Dirichlet process can be extended to more general models and provides a consistent method to estimate the number of components.
2210.14201v2.pdf (1.95 Mo) Télécharger le fichier
hal-03866434 , version 1 (22-11-2022)
hal-03866434 , version 2 (22-02-2023)
Louise Alamichel, Daria Bystrova, Julyan Arbel, Guillaume Kon Kam King. Bayesian mixture models (in)consistency for the number of clusters. 2023. ⟨hal-03866434v2⟩
77 Consultations
137 Téléchargements
