Filtering participants improves generalization in competitions and benchmarks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We address the problem of selecting a winning algorithm in a challenge or benchmark. While evaluations of algorithms carried out by third party organizers eliminate the inventor-evaluator bias, little attention has been paid to the risk of over-fitting the winner's selection by the organizers. In this paper, we carry out an empirical evaluation using the results of several challenges and benchmarks, evidencing this phenomenon. We show that a heuristic commonly used by organizers consisting of pre-filtering participants using a trial run, reduces over-fitting. We formalize this method and derive a semi-empirical formula to determine the optimal number of top k participants to retain from the trial run.
ESANN__Judging_Competitions__a_Meta_Learning_Perspective.pdf (511.85 Ko) Télécharger le fichier
hal-03869648 , version 1 (24-11-2022)
  • HAL Id : hal-03869648 , version 1
Adrien Pavao, Zhengying Liu, Isabelle Guyon. Filtering participants improves generalization in competitions and benchmarks. ESANN 2022 - European Symposium on Artificial Neural Networks, Oct 2022, Bruges, Belgium. ⟨hal-03869648⟩
50 Consultations
65 Téléchargements
