Point‐Pattern Synthesis using Gabor and Random Filters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2022
Point pattern synthesis requires capturing both local and non-local correlations from a given exemplar. Recent works employ deep hierarchical representations from VGG-19 [SZ15] convolutional network to capture the features for both point-pattern and texture synthesis. In this work, we develop a simplified optimization pipeline that uses more traditional Gabor transform-based features. These features when convolved with simple random filters gives highly expressive feature maps. The resulting framework requires significantly less feature maps compared to VGG-19-based methods [TLH19; RGF∗20], better captures both the local and non-local structures, does not require any specific data set training and can easily extend to handle multi-class and multi-attribute point patterns, e.g., disk and other element distributions. To validate our pipeline, we perform qualitative and quantitative analysis on a large variety of point patterns to demonstrate the effectiveness of our approach. Finally, to better understand the impact of random filters, we include a spectral analysis using filters with different frequency bandwidths.
hal-03872364 , version 1 (25-11-2022)
Xingchang Huang, Pooran Memari, Hans‐peter Seidel, Gurprit Singh. Point‐Pattern Synthesis using Gabor and Random Filters. Computer Graphics Forum, 2022, 41 (4), pp.169-179. ⟨10.1111/cgf.14596⟩. ⟨hal-03872364⟩
27 Consultations
0 Téléchargements
