The ICO Tool Suite: Optimizing Highly Configurable Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Working Paper) Année : 2023
Amirhosein Taherkordi
  • Fonction : Auteur
  • PersonId : 864406
Clément Quinton
Dealing with large configuration spaces is a complex task for developers, especially when manually searching for the configuration that best suits some given requirements. In this paper, we present the ICO tool suite, a set of software components designed to help developers optimize their configuration w.r.t a set of performance indicators. This tool suite can be used through a command-line client or an Eclipse plugin, while the loose coupling with its core library make it flexible-enough to be integrated into existing tools. ICO is assessed by evaluating the time it saves to users over a manual optimization.
ICODemo.pdf (352.98 Ko) Télécharger le fichier
hal-03874051 , version 1 (27-11-2022)
hal-03874051 , version 2 (16-03-2023)
  • HAL Id : hal-03874051 , version 2
Edouard Guégain, Amirhosein Taherkordi, Clément Quinton. The ICO Tool Suite: Optimizing Highly Configurable Systems. 2023. ⟨hal-03874051v2⟩
60 Consultations
71 Téléchargements
