Parallelizable Synthesis of Arbitrary Single-Qubit Gates with Linear Optics and Time-Frequency Encoding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review A Année : 2023
We propose novel methods for the exact synthesis of single-qubit unitaries with high success probability and gate fidelity, considering both time-bin and frequency-bin encodings. The proposed schemes are experimentally implementable with a spectral linear-optical quantum computation (S-LOQC) platform, composed of electro-optic phase modulators and phase-only programmable filters (pulse shapers). We assess the performances in terms of fidelity and probability of the two simplest 3-components configurations for arbitrary gate generation in both encodings and give an exact analytical solution for the synthesis of an arbitrary single-qubit unitary in the time-bin encoding, using a single-tone Radio Frequency (RF) driving of the EOMs. We further investigate the parallelization of arbitrary single-qubit gates over multiple qubits with a compact experimental setup, both for spectral and temporal encodings. We systematically evaluate and discuss the impact of the RF bandwidththat conditions the number of tones driving the modulators-and of the choice of encoding for different targeted gates. We moreover quantify the number of high fidelity Hadamard gates that can be synthesized in parallel, with minimal and increasing resources in terms of driving RF tones in a realistic system. Our analysis positions spectral S-LOQC as a promising platform to conduct massively parallel single qubit operations, with potential applications to quantum metrology and quantum tomography.
2210.11830.pdf (858.4 Ko) Télécharger le fichier
hal-03876857 , version 1 (07-11-2022)
hal-03876857 , version 2 (22-12-2022)
Paternité
Antoine Henry, Ravi Raghunathan, Guillaume Ricard, Baptiste Lefaucher, Filippo Miatto, et al.. Parallelizable Synthesis of Arbitrary Single-Qubit Gates with Linear Optics and Time-Frequency Encoding. Physical Review A, 2023, 107 (6), pp.062610. ⟨10.1103/PhysRevA.107.062610⟩. ⟨hal-03876857v2⟩
204 Consultations
46 Téléchargements
