Streaming Regular Expression Membership and Pattern Matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2022
Regular expression search is a key primitive in myriads of applications, from web scrapping to bioinformatics. A regular expression is a formalism for compactly describing a set of strings, built recursively from single characters using three operators: concatenation, union, and Kleene star. Two basic algorithmic problems concerning such expressions are membership and pattern matching. In the regular expression membership problem, we are given a regular expression R and a string T of length n, and must decide whether T matches R. In the regular expression pattern matching problem, the task to find the substrings of T that match R. By now we have a good understanding of the complexity of regular expression membership and pattern matching in the classical setting. However, only some special cases have been considered in the practically relevant streaming setting: dictionary matching and wildcard pattern matching. In the dictionary matching problem, we are given a dictionary of d strings of length at most m and a string T, and must find substrings of T that match one of the dictionary strings. In the wildcard pattern matching problem, we are given a string P of length m that contains d wildcards, where a wildcard is a special symbol that matches any character of the alphabet, and a string T, and must find all substrings of T that match P. Both problems can be solved in the streaming model by a randomised Monte Carlo algorithm that uses O(d log m) space [Golan and Porat (ESA 2017), Golan, Kopelowitz and Porat (Algorithmica 2019)]. In the general case, we cannot hope for a streaming algorithm with space complexity smaller than the length of R for either variant of regular expression search. The main contribution of this paper is that we identify the number of unions and Kleene stars, denoted by d, as the parameter that allows for an efficient streaming algorithm. This parameter has been previously considered in the classical setting, and it has been observed that in practice it is significantly smaller than the length of R. We design general randomised Monte Carlo algorithms for both problems that use O(d^3 polylog n) space in the streaming setting. A crucial technical ingredient of our algorithms is an adaptation of the general framework for evaluating a circuit with addition and convolution gates in a space-efficient manner [Lokshtanov and Nederlof (STOC 2010), Bringmann (SODA 2017)], initially designed as a key component of a pseudopolynomial time algorithm for the subset sum problem. We show how to replace the Extended Generalised Riemann Hypothesis in [Bringmann (SODA 2017)] by an application of the Bombieri-Vinogradov theorem to achieve the same bounds (but unconditionally), which might be of independent interest.
1.9781611977073.30.pdf (1.13 Mo) Télécharger le fichier
hal-03887523 , version 1 (06-12-2022)
Bartłomiej Dudek, Paweł Gawrychowski, Garance Gourdel, Tatiana Starikovskaya. Streaming Regular Expression Membership and Pattern Matching. Proceedings of the 2022 Annual ACM-SIAM Symposium on Discrete Algorithms (SODA), Society for Industrial and Applied Mathematics, pp.670-694, 2022, ⟨10.1137/1.9781611977073.30⟩. ⟨hal-03887523⟩
20 Consultations
65 Téléchargements
