Decentralized in-order execution of a sequential task-based code for shared-memory architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The hardware complexity of modern machines makes the design of adequate programming models crucial for jointly ensuring performance, portability, and productivity in high-performance computing (HPC). Sequential task-based programming models paired with advanced runtime systems allow the programmer to write a sequential algorithm independently of the hardware architecture in a productive and portable manner, and let a third party software layer-the runtime system-deal with the burden of scheduling a correct, parallel execution of that algorithm to ensure performance. Many HPC algorithms have successfully been implemented following this paradigm, as a testimony of its effectiveness. Developing algorithms that specifically require fine-grained tasks along this model is still considered prohibitive, however, due to per-task management overhead [1], forcing the programmer to resort to a less abstract, and hence more complex "task+X" model. We thus investigate the possibility to offer a tailored execution model, trading dynamic mapping for efficiency by using a decentralized, conservative in-order execution of the task flow, while preserving the benefits of relying on the sequential taskbased programming model. We propose a formal specification of the execution model as well as a prototype implementation, which we assess on a shared-memory multicore architecture with several synthetic workloads. The results show that under the condition of a proper task mapping supplied by the programmer, the pressure on the runtime system is significantly reduced and the execution of fine-grained task flows is much more efficient.
ccastes_hips_2022.pdf (416 Ko) Télécharger le fichier
hal-03896030 , version 1 (13-12-2022)
Charly Castes, Emmanuel Agullo, Olivier Aumage, Emmanuelle Saillard. Decentralized in-order execution of a sequential task-based code for shared-memory architectures. IPDPSW 2022 - IEEE International Parallel and Distributed Processing Symposium Workshops, May 2022, Lyon, France. pp.552-561, ⟨10.1109/IPDPSW55747.2022.00095⟩. ⟨hal-03896030⟩
Collections
CNRS INRIA INRIA2
29 Consultations
74 Téléchargements
