Model of Bacteria Mutualism in a Chemostat: Analysis and Optimization with Interval Detector - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work focuses on a model of two bacteria growing and exchanging nutrients in a chemostat. Bacterial uptake rate is described via Michaelis-Menten equations; we assume a constant yield and metabolite production directly proportional to bacterial growth. We analyse the model via a reduced order system, then, conditions to determine existence and global stability of the equilibria are given in terms of the dilution rate. Finally, bacterial productivity is maximized; an interval detector is designed to estimate this productivity and an optimization strategy for periodic dilution rates is proposed.
_Final_CDC_2022__Model_of_Bacteria_Mutualism_in_a_Chemostat__Analysis_and_Optimization_with_Interval_Detector.pdf (831.82 Ko) Télécharger le fichier
hal-03903952 , version 1 (16-12-2022)
  • HAL Id : hal-03903952 , version 1
Juan Carlos Arceo, Olivier Bernard, Jean-Luc Gouzé. Model of Bacteria Mutualism in a Chemostat: Analysis and Optimization with Interval Detector. CDC 2022 - Conference on Decision and Control, Dec 2022, Cancun, Mexico. ⟨hal-03903952⟩
52 Consultations
33 Téléchargements
