Predicting the Score of Atomic Candidate OWL Class Axioms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Candidate axiom scoring is the task of assessing the acceptability of a candidate axiom against the evidence provided by known facts or data. The ability to score candidate axioms reliably is required for automated schema or ontology induction, but it can also be valuable for ontology and/or knowledge graph validation. Accurate axiom scoring heuristics are often computationally expensive, which is an issue if you wish to use them in iterative search techniques like level-wise generate-and-test or evolutionary algorithms, which require scoring a large number of candidate axioms. We address the problem of developing a predictive model as a substitute for reasoning that predicts the possibility score of candidate class axioms and is quick enough to be employed in such situations. We use a semantic similarity measure taken from an ontology's subsumption structure for this purpose. We show that the approach provided in this work can accurately learn the possibility scores of candidate OWL class axioms and that it can do so for a variety of OWL class axioms.
Predicting_the_possibility_of_Atomic_Candidate_OWL_Class_Axioms_WI_Accepted (1).pdf (298.12 Ko) Télécharger le fichier
hal-03905409 , version 1 (18-12-2022)
  • HAL Id : hal-03905409 , version 1
Ali Ballout, Andrea G B Tettamanzi, Célia da Costa Pereira. Predicting the Score of Atomic Candidate OWL Class Axioms. WI-IAT 2022 - 21st IEEE/WIC/ACM International Conference on Web Intelligence and Intelligent Agent Technology, Nov 2022, Niagara Falls, Canada. ⟨hal-03905409⟩
50 Consultations
15 Téléchargements
