A System of Interaction and Structure III: The Complexity of BV and Pomset Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Logical Methods in Computer Science Année : 2023
Pomset logic and BV are both logics that extend multiplicative linear logic (with Mix) with a third connective that is self-dual and non-commutative. Whereas pomset logic originates from the study of coherence spaces and proof nets, BV originates from the study of series-parallel orders, cographs, and proof systems. Both logics enjoy a cut-admissibility result, but for neither logic can this be done in the sequent calculus. Provability in pomset logic can be checked via a proof net correctness criterion and in BV via a deep inference proof system. It has long been conjectured that these two logics are the same. In this paper we show that this conjecture is false. We also investigate the complexity of the two logics, exhibiting a huge gap between the two. Whereas provability in BV is NPcomplete, provability in Pomset logic is Σ p 2-complete. We also make some observations with respect to possible sequent systems for the two logics.
2209.07825.pdf (1.02 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-03909547 , version 1 (21-12-2022)
hal-03909547 , version 2 (10-01-2024)
Paternité
Lê Thành Dũng Nguyên, Lutz Straßburger. A System of Interaction and Structure III: The Complexity of BV and Pomset Logic. Logical Methods in Computer Science, 2023, 9 (4), ⟨10.46298/LMCS-19(4:25)2023⟩. ⟨hal-03909547v2⟩
114 Consultations
65 Téléchargements
