Capturing program models with BISM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present an extension of the Java bytecode instrumentation tool BISM that captures and prepares a model that abstracts the program behavior at the intra-procedural level. We analyze program methods we are interested in monitoring and construct a control-flow graph automaton where the states represent actions of the program that produce events. Directed towards monitoring general behavioral properties at runtime, the resulting model is presented for the users to write static analyzers and combine both static and runtime verification.
sac22.pdf (298.65 Ko) Télécharger le fichier
hal-03911682 , version 1 (23-12-2022)
Chukri Soueidi, Yliès Falcone. Capturing program models with BISM. SAC 2022 - 37th ACM Symposium on Applied Computing - Software Verification and Testing Track, Apr 2022, Brno (Virtuel), Czech Republic. ⟨10.1145/3477314.3507239⟩. ⟨hal-03911682⟩
70 Consultations
59 Téléchargements
