O programa residência pedagógica: uma reflexão tomando por base a experiência francesa. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Educação Matemática Pesquisa Année : 2022
The pedagogical residency program: a reflection based on the french experience.
El programa de residencia pedagógica: una reflexión a partir de la experiencia francesa.
Le programme de résidence pédagogique : une réflexion à partir de l'expérience française
This article aims to broaden the debate about pedagogical residency in Brazil by making a comparison with what occurs in France, emphasisingthe initial educationof mathematics teachers. France is undergoing changes in its national education system, one of the goals of which is to improve mathematics performance, which has been declining for the past 30 years. In the framework of a great plan that is beginning to be implemented in French national education, we have the investment in the conditions of the teaching performance as one of the strong points of the reform, which brings as one of the measures a pre-professionalization proposal. We try to compare that proposalwith the pedagogical residency in Brazil, without ignoringthe historical and cultural differences. To do so, we conducted an exploratoryresearch based on current official documents available from the Brazilian and French governments about the proposals that have been occurring in mathematics teaching. This research was done as part of a post-doctoral studyin France. Among the results observed in France, we consider that an extension of the duration of the pedagogical residency in Brazil initially proposed by CAPES would be pertinent, as well as an increase in the value of the grants, toappreciate initial teacher education. We also believe that it is necessary to have a national project to value the teaching career in Brazil with more investments in education.
Este artículo pretende ampliar el debate sobre la residencia pedagógica en Brasil en comparación con Francia, con énfasis en la formación inicial del(la)profesor(a)de matemáticas. Francia está experimentando cambios en su sistema educativo nacional. Uno de sus objetivos es mejorar el resultado discente en matemáticas, que ha disminuido en los últimos 30 años. En el marco de un gran plan que comienza a implementarse en la educación nacional francesa, tenemos la inversión en las condiciones del desempeño docente como uno de los puntos fuertes de la reforma, que trae como una de las medidas una propuesta de pre-profesionalización en Francia. Intentamos comparar esa propuesta con la residencia pedagógica en Brasil, sin olvidar las diferencias históricas y culturales. Para ello, realizamos una investigación exploratoria a partir de una base de datos documentales oficiales vigentes disponibles de los gobiernos brasileño y francés sobre las propuestas que se vienen dando en la enseñanza de las matemáticas. Esta investigación tuvo lugar en el marco de una investigación posdoctoral en Francia. Entre los resultados observados en Francia, consideramos que sería pertinente prolongar la duración de la residencia pedagógica en Brasil inicialmente propuesta por la CAPES, así como aumentar el valor de las becas, para valorizar la formación inicial de los docentes. También creemos que es necesario un proyecto nacional para valorar la carrera docente en Brasil con más inversiones en educación.
Cet article vise à élargir le débat sur la Résidence Pédagogique au Brésil en faisant une comparaison avec ce qui se passe en France, en mettant l'accent sur la formation initiale du professeur de Mathématiques. La France connaît des mutations au sein du système de l'Éducation nationale qui ont pour objectif d'améliorer les performances en mathématiques, en baisse depuis 30 ans. Dans le cadre d'un grand plan qui commence à être mis en œuvre dans l'Éducation nationale de France, nous avons relevé l'investissement dans les conditions d’exercice du métier d’enseignant comme l’un des points forts de la réforme, qui introduit dans les mesures proposées celle de la préprofessionnalisation. Nous avons essayé de comparer la proposition de préprofessionnalisation en France avec le dispositif de Résidence Pédagogique au Brésil, en gardant à l’esprit les différences historico-culturelles. Pour ce faire, nous avons conduit une recherche d’orientation méthodologique exploratoire en nous basant sur une base de données construite à partir des documents officiels actuels des gouvernements brésilien et français qui nous étaient accessibles portant sur les propositions en cours dans l’enseignement des mathématiques. Cette recherche a été conduite dans le contexte d’un stage postdoctoral en France. A partir de résultats observés en France,nous considérons qu’il serait pertinent d’allonger la durée de la Résidence Pédagogique au Brésil initialement proposée par le CAPES, ainsi que l’augmentation du montant des bourses d’étude, afin de générer une valorisation de la formation initiale des enseignants. Nous pensons aussi qu'un projet national pour valoriser la carrière des enseignants au Brésil est également nécessaire, avec un investissement accru dans le domaine de l'éducation.
Este artigo tem como objetivo ampliar o debate sobre a residência pedagógica no Brasil fazendo um comparativo com o que ocorre na França, com ênfase na formação inicial de professores(as)de matemática. A França está passando por mudanças na educação nacional. Um dos objetivos é melhorar o desempenho discente em matemática que vem caindo nos últimos 30 anos. No quadro de um grande plano que começa a ser implementado na educação nacional da França,temos o investimento nas condições da atuação docente como um dos pontos fortes da reforma, que traz como uma das medidas uma proposta de pré-profissionalização. Procuramos comparar essa proposta com a residência pedagógica no Brasil, sem esquecer as diferenças histórico-culturais. Para tanto, realizamos uma pesquisa exploratória baseada em dados documentais oficiais atuais disponíveis dos governos brasileiro e francês sobre as propostas que vêm ocorrendo no ensino de matemática. Essa pesquisa deriva de um estudo de pós-doutorado na França. Entre os resultados observados na França, consideramos que seria pertinente a ampliação do tempo da residência pedagógica no Brasil proposto inicialmente pela CAPES, bem como aumento do valor das bolsas, de forma a valorizar a formação inicial docente. Consideramos que também se faz necessário um projeto nacional de valorização da carreira de professor(a)no Brasil com mais investimentos em educação.
hal-03913282 , version 1 (26-12-2022)
Vladimir Lira Veras Xavier de Andrade, Jean-Claude Régnier. O programa residência pedagógica: uma reflexão tomando por base a experiência francesa.. Educação Matemática Pesquisa, 2022, Formação de Professores de Matemática na interface com o Programa Residência Pedagógica, pp.096-137. ⟨10.23925/1983-3156.2022v24i4p096-137⟩. ⟨hal-03913282⟩
36 Consultations
0 Téléchargements
