Secure Computations in Opportunistic Networks: An Edgelet Demonstration with a Medical Use-Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ludovic Javet
  • Fonction : Auteur
  • PersonId : 1212283
Nicolas Anciaux
Luc Bouganim
Philippe Pucheral
In this demonstration paper, we leverage the current convergence between Trusted Execution Environments and Opportunistic Networks to perform secure and privacy-preserving computations on personal devices. We call this convergence Edgelet computing and show that it can drastically change the way distributed processing over personal data is conceived. We demonstrate the pertinence of the approach through a real medical use-case being deployed in the field.
PERCOM23_Vfinal.pdf (1015.71 Ko) Télécharger le fichier
hal-03925679 , version 1 (05-01-2023)
hal-03925679 , version 2 (23-01-2023)
hal-03925679 , version 3 (03-02-2023)
Paternité
Ludovic Javet, Nicolas Anciaux, Luc Bouganim, Léo Lamoureux, Philippe Pucheral. Secure Computations in Opportunistic Networks: An Edgelet Demonstration with a Medical Use-Case. PerCom 2023 - 21st IEEE International Conference on Pervasive Computing and Communications, Mar 2023, Atlanta, United States. pp.331-333, ⟨10.1109/PerComWorkshops56833.2023.10150321⟩. ⟨hal-03925679v3⟩
124 Consultations
74 Téléchargements
