Photonic power firewalls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cryptographic Engineering Année : 2022
Jean-Max Dutertre
Amir-Pasha Mirbaha
David Naccache
  • Fonction : Auteur
  • PersonId : 928358
Assia Tria
  • Fonction : Auteur
  • PersonId : 864381
This paper describes a new countermeasure against side-channel power attacks. We show that a conventional chipcard can be powered using an organic electroluminescent diode (OLED) facing a photovoltaic cell. By doing so, the card’s power consumption becomes constant and equal to the OLED’s power consumption. Despite size, energy conversion and heat dissipation issues, we believe that this countermeasure nicely suits several high-security applications. Because photonic power firewalls guarantee physical isolation, we recommend photonic firewalls for applications where energy and form factor considerations are not as important as security ( e.g., diplomatic encryption devices).
Fichier non déposé
hal-03932237 , version 1 (10-01-2023)
  • HAL Id : hal-03932237 , version 1
Jean-Max Dutertre, Amir-Pasha Mirbaha, David Naccache, Assia Tria. Photonic power firewalls. Journal of Cryptographic Engineering, 2022, 12, pp.245-254. ⟨hal-03932237⟩
5 Consultations
0 Téléchargements
