The graph embedded topic model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neurocomputing Année : 2023
Most of existing graph neural networks (GNNs) developed for the prevalent text-rich networks typically treat texts as node attributes. This kind of approach unavoidably results in the loss of important semantic structures and restricts the representational power of GNNs. In this work, we introduce a document similarity-based graph convolutional network (DS-GCN) encoder to combine graph convolutional networks and embedded topic models for text-rich network representation. Then, a latent position-based decoder is used to reconstruct the graph while preserving the network topology. Similarly, the document matrix is rebuilt using a decoder that takes both topic and word embeddings into account. By including a cluster membership variable for each node in the network, we thus develop an end-to-end clustering technique relying on a new deep probabilistic model called the graph embedded topic model (GETM). Numerical experiments on three simulated scenarios emphasize the ability of GETM in fusing the graph topology structure and the document embeddings, and highlight its node clustering performance. Moreover, an application on the Cora-enrich citation network is conducted to demonstrate the e↵ectiveness and interest of GETM in practice.
article_GETM_HAL.pdf (3.49 Mo) Télécharger le fichier
hal-03942487 , version 1 (17-01-2023)
Dingge Liang, Marco Corneli, Charles Bouveyron, Pierre Latouche. The graph embedded topic model. Neurocomputing, 2023, 562, pp.126900. ⟨10.1016/j.neucom.2023.126900⟩. ⟨hal-03942487⟩
166 Consultations
194 Téléchargements
