Variable selection with Multi-Layer Group Lasso - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The MLGL (Multi-Layer Group-Lasso) R package implements a new procedure of variable selection in the context of redundancy between explanatory variables, which holds true with high0dimensional data. A sparsity assumption is made–that is, only a few variables are assumed to be relevant for predicting the response variable. In this context, the performance of classical Lasso-based approaches strongly deteriorates as the redundancy strengthens.The proposed approach combines variables aggregation and selection in order to improve interpretability and performance. First, a hierarchical clustering procedure provides at each level a partition of the variables into groups. Then, the set of groups of variables from the different levels of the hierarchy is given as input to group-Lasso, with weights adapted to the structure of the hierarchy. At this step, group-Lasso outputs sets of candidate groups of variables for each value of regularization parameter.The versatility offered by MLGL to choose groups at different levels of the hierarchy a priori induces a high computational complexity. MLGL, however, exploits the structure of the hierarchy and the weights used in group-Lasso to greatly reduce the final time cost. The final choice of the regularization parameter–and therefore the final choice of groups–is made by a multiple hierarchical testing procedure.
MLGL.pdf (265.07 Ko) Télécharger le fichier
hal-03942579 , version 1 (17-01-2023)
  • HAL Id : hal-03942579 , version 1
Guillemette Marot, Quentin Grimonprez, Samuel Blanck, Alain Celisse. Variable selection with Multi-Layer Group Lasso. useR! 2022, Jun 2022, Virtual, United States. ⟨hal-03942579⟩
35 Consultations
76 Téléchargements
