Approximate Bayesian computation with the sliced-Wasserstein distance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Approximate Bayesian Computation (ABC) is a popular method for approximate inference in generative models with intractable but easy-to-sample likelihood. It constructs an approximate posterior distribution by finding parameters for which the simulated data are close to the observations in terms of summary statistics. These statistics are defined beforehand and might induce a loss of information, which has been shown to deteriorate the quality of the approximation. To overcome this problem, Wasserstein-ABC has been recently proposed, and compares the datasets via the Wasserstein distance between their empirical distributions, but does not scale well to the dimension or the number of samples. We propose a new ABC technique, called Sliced-Wasserstein ABC and based on the Sliced-Wasserstein distance, which has better computational and statistical properties. We derive two theoretical results showing the asymptotical consistency of our approach, and we illustrate its advantages on synthetic data and an image denoising task.
1910.12815.pdf (980.87 Ko) Télécharger le fichier
hal-03945515 , version 1 (16-01-2024)
Kimia Nadjahi, Valentin de Bortoli, Alain Durmus, Roland Badeau, Umut Şimşekli. Approximate Bayesian computation with the sliced-Wasserstein distance. 2022. ⟨hal-03945515⟩
44 Consultations
19 Téléchargements
