Timed Automata Verification and Synthesis via Finite Automata Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present algorithms for model checking and controller synthesis of timed automata, seeing a timed automaton model as a parallel composition of a large finite-state machine and a relatively smaller timed automaton, and using compositional reasoning on this composition. We use automata learning algorithms to learn finite automata approximations of the timed automaton component, in order to reduce the problem at hand to finite-state model checking or to finite-state controller synthesis. We present an experimental evaluation of our approach.
main.pdf (405.38 Ko) Télécharger le fichier
hal-03947462 , version 1 (19-01-2023)
Paternité
  • HAL Id : hal-03947462 , version 1
Ocan Sankur. Timed Automata Verification and Synthesis via Finite Automata Learning. TACAS 2023 - 29th International Conference on Tools and Algorithms for the Construction and Analysis of Systems, Apr 2023, Paris, France. pp.329-349. ⟨hal-03947462⟩
132 Consultations
234 Téléchargements
