The Lannion report on Big Data and Security Monitoring Research - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Omer Rana
  • Fonction : Auteur
  • PersonId : 1218396
Le Gruenwald
  • Fonction : Auteur
  • PersonId : 999621
Hervé Rannou
  • Fonction : Auteur
  • PersonId : 1066700
Elisa Bertino
  • Fonction : Auteur
  • PersonId : 1218393
Taofik Saïdi
  • Fonction : Auteur
  • PersonId : 1218397
Georges Bossert
  • Fonction : Auteur
  • PersonId : 1218394
Dimitri Tombroff
  • Fonction : Auteur
  • PersonId : 1218398
During the last decade, big data management has attracted increasing interest from both the industrial and academic communities. In parallel, Cyber Security has become mandatory due to various and more intensive threats. In June 2022, a group of researchers has met to reflect on their community's impacts on current research challenges. In particular, they have considered four dimensions: (1) dedicated systems being data processing and analytic platforms or time series management systems; (2) graphs analytics and distributed computation; (3) privacy; and (4) new hardware.
SUPSEC_BigData.pdf (480.98 Ko) Télécharger le fichier
hal-03951141 , version 1 (22-01-2023)
Laurent d'Orazio, Jalil Boukhobza, Omer Rana, Juba Agoun, Le Gruenwald, et al.. The Lannion report on Big Data and Security Monitoring Research. Workshop on Big Data for CyberSecurity (BigCyber-2022), Dec 2022, Osaka, Japan. pp.2960-2969, ⟨10.1109/BigData55660.2022.10020852⟩. ⟨hal-03951141⟩
82 Consultations
85 Téléchargements
