Privacy Amplification via Shuffling for Linear Contextual Bandits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Contextual bandit algorithms are widely used in domains where it is desirable to provide a personalized service by leveraging contextual information, that may contain sensitive information that needs to be protected. Inspired by this scenario, we study the contextual linear bandit problem with differential privacy (DP) constraints. While the literature has focused on either centralized (joint DP) or local (local DP) privacy, we consider the shuffle model of privacy and we show that is possible to achieve a privacy/utility trade-off between JDP and LDP. By leveraging shuffling from privacy and batching from bandits, we present an algorithm with regret bound $\widetilde{\mathcal{O}}(T^{2/3}/\varepsilon^{1/3})$, while guaranteeing both central (joint) and local privacy. Our result shows that it is possible to obtain a trade-off between JDP and LDP by leveraging the shuffle model while preserving local privacy.
hal-03951300 , version 1 (23-01-2023)
Evrard Garcelon, Kamalika Chaudhuri, Vianney Perchet, Matteo Pirotta. Privacy Amplification via Shuffling for Linear Contextual Bandits. The 33rd International Conference on Algorithmic Learning Theory, 2022, Paris, France. ⟨hal-03951300⟩
20 Consultations
0 Téléchargements
