Reproducibility in machine learning for medical imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
Reproducibility is a cornerstone of science, as the replication of findings is the process through which they become knowledge. It is widely considered that many fields of science are undergoing a reproducibility crisis. This has led to the publications of various guidelines in order to improve research reproducibility. This didactic chapter intends at being an introduction to reproducibility for researchers in the field of machine learning for medical imaging. We first distinguish between different types of reproducibility. For each of them, we aim at defining it, at describing the requirements to achieve it and at discussing its utility. The chapter ends with a discussion on the benefits of reproducibility and with a plea for a non-dogmatic approach to this concept and its implementation in research practice.
Chapter 21 - Final.pdf (352.33 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-03957240 , version 1 (26-01-2023)
hal-03957240 , version 2 (20-04-2023)
Paternité
  • HAL Id : hal-03957240 , version 2
Olivier Colliot, Elina Thibeau-Sutre, Ninon Burgos. Reproducibility in machine learning for medical imaging. Olivier Colliot. Machine Learning for Brain Disorders, Springer, 2023. ⟨hal-03957240v2⟩
142 Consultations
63 Téléchargements
