Cross-Domain Consistent Fingerprint Denoising - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Sensors Letters Année : 2022
Performance of state-of-the-art fingerprint denoising model on poor quality fingerprints degrades due to crossdomain shift observed between training and testing domains. To address this limitation, we present a cross-domain consistent fingerprint denoising model, which ensures that the output of two fingerprint images with the same ridge structure, however varying contrast and ridge-valley clarity should be similar. Results indicate that the proposed CDC-GAN outperforms state-of-the-art fingerprint denoising algorithms on challenging publicly available poor quality fingerprint databases.
sensorsl22_cross_domain (1).pdf (1.64 Mo) Télécharger le fichier
hal-03966789 , version 1 (31-01-2023)
Indu Joshi, Tashvik Dhamija, Rohit Kumar, Antitza Dantcheva, Sumantra Dutta Roy, et al.. Cross-Domain Consistent Fingerprint Denoising. IEEE Sensors Letters, 2022, 6 (8), ⟨10.1109/LSENS.2022.3193924⟩. ⟨hal-03966789⟩
24 Consultations
48 Téléchargements
