Detecting subtle signs of depression with automated speech analysis in a non-clinical sample - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BMC Psychiatry Année : 2022
Johannes Tröger
  • Fonction : Auteur
Elisa Mallick
  • Fonction : Auteur
Mario Mina
  • Fonction : Auteur
Nicklas Linz
  • Fonction : Auteur
Carole Wagnon
  • Fonction : Auteur
Julia Karbach
  • Fonction : Auteur
Caroline Kuhn
  • Fonction : Auteur
Jessica Peter
  • Fonction : Auteur
Background: Automated speech analysis has gained increasing attention to help diagnosing depression. Most previous studies, however, focused on comparing speech in patients with major depressive disorder to that in healthy volunteers. An alternative may be to associate speech with depressive symptoms in a non-clinical sample as this may help to find early and sensitive markers in those at risk of depression. Methods: We included n = 118 healthy young adults (mean age: 23.5 ± 3.7 years; 77% women) and asked them to talk about a positive and a negative event in their life. Then, we assessed the level of depressive symptoms with a self-report questionnaire, with scores ranging from 0-60. We transcribed speech data and extracted acoustic as well as linguistic features. Then, we tested whether individuals below or above the cutoff of clinically relevant depressive symptoms differed in speech features. Next, we predicted whether someone would be below or above that cutoff as well as the individual scores on the depression questionnaire. Since depression is associated with cognitive slowing or attentional deficits, we finally correlated depression scores with performance in the Trail Making Test. Results: In our sample, n = 93 individuals scored below and n = 25 scored above cutoff for clinically relevant depressive symptoms. Most speech features did not differ significantly between both groups, but individuals above cutoff spoke more than those below that cutoff in the positive and the negative story. In addition, higher depression scores in that group were associated with slower completion time of the Trail Making Test. We were able to predict with 93% accuracy who would be below or above cutoff. In addition, we were able to predict the individual depression scores with low mean absolute error (3.90), with best performance achieved by a support vector machine. Conclusions: Our results indicate that even in a sample without a clinical diagnosis of depression, changes in speech relate to higher depression scores. This should be investigated in more detail in the future. In a longitudinal study, it may be tested whether speech features found in our study represent early and sensitive markers for subsequent depression in individuals at risk.
Koenig2022-BMC.pdf (1.1 Mo) Télécharger le fichier
hal-03968260 , version 1 (14-03-2023)
Alexandra König, Johannes Tröger, Elisa Mallick, Mario Mina, Nicklas Linz, et al.. Detecting subtle signs of depression with automated speech analysis in a non-clinical sample. BMC Psychiatry, 2022, 22, ⟨10.1186/s12888-022-04475-0⟩. ⟨hal-03968260⟩
19 Consultations
21 Téléchargements
