Zooids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
Zooids
Mathieu Le Goc
  • Fonction : Auteur
Charles Perin
Sean Follmer
  • Fonction : Auteur
Jean-Daniel Fekete
Pierre Dragicevic
Physical data visualizations tap into our lifelong experience of perceiving and manipulating the physical world, either alone or with other people. However, most physical visualizations are either monolithic and static, or require human intervention to be rearranged. We drew inspiration from existing physical interactive systems and data storytelling practices with physical tokens (like those of the influential Swedish professor Hans Rosling) to develop Zooids, tiny wheeled robots that can move rapidly on any horizontal surface. We used Zooids to explore physical data visualizations that can (1) be manipulated by humans, and (2) update themselves through computerized mechanisms.
Chapter Text - Zooids.pdf (27.31 Mo) Télécharger le fichier
Licence : CC BY NC ND - Paternité - Pas d'utilisation commerciale - Pas de modification
Format : Figure, Image
hal-03978632 , version 1 (24-02-2023)
  • HAL Id : hal-03978632 , version 1
Mathieu Le Goc, Charles Perin, Sean Follmer, Jean-Daniel Fekete, Pierre Dragicevic. Zooids. Samuel Huron; Till Nagel; Lora Oehlberg; Wesley Willett. Making with Data: Physical Design and Craft in a Data-Driven World, A K Peters/CRC Press, 2023, 9781032207223. ⟨hal-03978632⟩
131 Consultations
33 Téléchargements
