Elimination ideal and bivariate resultant over finite fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new algorithm is presented for computing the largest degree invariant factor of the Sylvester matrix (with respect either to $x$ or $y$) associated to two polynomials $a$ and $b$ in $\mathbb F_q[x,y]$ which have no non-trivial common divisors. The algorithm is randomized of the Monte Carlo type and requires $O((de)^{1+\epsilon}\log(q) ^{1+o(1)})$ bit operations, where $d$ an $e$ respectively bound the input degrees in $x$ and in $y$. It follows that the same complexity estimate is valid for computing: a generator of the elimination ideal $\langle a,b \rangle \cap \mathbb F_q[x]$ (or $\mathbb F_q[y]$), as soon as the polynomial system $a=b=0$ has not roots at infinity; the resultant of $a$ and $b$ when they are sufficiently generic, especially so that the Sylvester matrix has a unique non-trivial invariant factor. Our approach is to use the reduction of the problem to a problem of minimal polynomial in the quotient algebra $\mathbb F_q[x,y]/\langle a,b \rangle$. By proposing a new method based on structured polynomial matrix division for computing with the elements in the quotient, we manage to improve the best known complexity bounds.
ms.pdf (179.09 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-03999414 , version 1 (21-02-2023)
Paternité
Gilles Villard. Elimination ideal and bivariate resultant over finite fields. ISSAC 2023: International Symposium on Symbolic and Algebraic Computation 2023, Jul 2023, Tromsø Norway, Norway. pp.526-534, ⟨10.1145/3597066.3597100⟩. ⟨hal-03999414⟩
53 Consultations
127 Téléchargements
