Cybersickness, Cognition, & Motor Skills: The Effects of Music, Gender, and Gaming Experience - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2023
Recent research has attempted to identify methods to mitigate cybersickness and examine its aftereffects. In this direction, this paper examines the effects of cybersickness on cognitive, motor, and reading performance in VR. Also, this paper evaluates the mitigating effects of music on cybersickness, as well as the role of gender, and the computing, VR, and gaming experience of the user. This paper reports two studies. In the 1st study, 92 participants selected the music tracks considered most calming (low valence) or joyful (high valence) to be used in the 2nd study. In the 2nd study, 39 participants performed an assessment four times, once before the rides (baseline), and then once after each ride (3 rides). In each ride either Calming, or Joyful, or No Music was played. During each ride, linear and angular accelerations took place to induce cybersickness in the participants. In each assessment, while immersed in VR, the participants evaluated their cybersickness symptomatology and performed a verbal working memory task, a visuospatial working memory task, and a psychomotor task. While responding to the cybersickness questionnaire (3D UI), eye-tracking was conducted to measure reading time and pupillometry. The results showed that Joyful and Calming music substantially decreased the intensity of nausea-related symptoms. However, only Joyful music significantly decreased the overall cybersickness intensity. Importantly, cybersickness was found to decrease verbal working memory performance and pupil size. Also, it significantly decelerated psychomotor (reaction time) and reading abilities. Higher gaming experience was associated with lower cybersickness. When controlling for gaming experience, there were no significant differences between female and male participants in terms of cybersickness. The outcomes indicated the efficiency of music in mitigating cybersickness, the important role of gaming experience in cybersickness, and the significant effects of cybersickness on pupil size, cognition, psychomotor skills, and reading ability.
Cybersickness__Cognition____Motor_Skills__The_Effects_of_Music__Gender__and_Gaming_Experience (2).pdf (2.66 Mo) Télécharger le fichier
hal-04004668 , version 1 (25-02-2023)
Panagiotis Kourtesis, Rayaan Amir, Josie Linnell, Ferran Argelaguet, Sarah Macpherson. Cybersickness, Cognition, & Motor Skills: The Effects of Music, Gender, and Gaming Experience. IEEE Transactions on Visualization and Computer Graphics, 2023, pp.1-11. ⟨10.1109/TVCG.2023.3247062⟩. ⟨hal-04004668⟩
49 Consultations
73 Téléchargements
