High-dimensional analysis of double descent for linear regression with random projections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Francis Bach
  • Fonction : Auteur
  • PersonId : 863086
We consider linear regression problems with a varying number of random projections, where we provably exhibit a double descent curve for a fixed prediction problem, with a high-dimensional analysis based on random matrix theory. We first consider the ridge regression estimator and review earlier results using classical notions from non-parametric statistics, namely degrees of freedom, also known as effective dimensionality. We then compute asymptotic equivalents of the generalization performance (in terms of squared bias and variance) of the minimum norm least-squares fit with random projections, providing simple expressions for the double descent phenomenon.
double_descent_linear_reg_random_proj_v2.pdf (493.5 Ko) Télécharger le fichier
hal-04008311 , version 1 (01-03-2023)
hal-04008311 , version 2 (13-03-2023)
Francis Bach. High-dimensional analysis of double descent for linear regression with random projections. 2023. ⟨hal-04008311v2⟩
43 Consultations
260 Téléchargements
