SurfAirs: Surface + Mid-air Input for Large Vertical Displays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Emmanuel Courtoux
Caroline Appert
Olivier Chapuis
Large vertical surfaces such as wall displays allow users to work with a very large and high-resolution workspace. Such displays promote physical navigation: users can step close to the display to see details, but also move away to get a wider view of the workspace. In terms of input, current solutions usually combine direct touch on the wall with input on a handheld device, disconnecting close and distant input rather than treating it as a continuum. We present SurfAirs, which are physical controllers that users can manipulate on screen (surface input), in the air (mid-air input), and transition from the surface to the air during a single manipulation (hybrid input). We report on two user studies that compare SurfAirs' performance with bare-hand input for both mid-air and hybrid input. Participants prefer and perform better with SurfAirs.
main.pdf (6.19 Mo) Télécharger le fichier
surfairs.mp4 (47.44 Mo) Télécharger le fichier
Format : Vidéo
hal-04009207 , version 1 (01-03-2023)
Emmanuel Courtoux, Caroline Appert, Olivier Chapuis. SurfAirs: Surface + Mid-air Input for Large Vertical Displays. CHI 2023 - International conference on Human factors in computing systems, Apr 2023, Hamburg, Germany. 15 p., ⟨10.1145/3544548.3580877⟩. ⟨hal-04009207⟩
109 Consultations
89 Téléchargements
