Covid-19 affects taste independently of smell: results from a combined chemosensory home test and online survey from a global cohort (N=10,953) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Abstract People often confuse smell loss with taste loss, so it is unclear how much gustatory function is reduced in patients self-reporting taste loss. Our pre-registered cross-sectional study design included an online survey in 12 languages with instructions for self-administering chemosensory tests with ten household items. Between June 2020 and March 2021, 10,953 individuals participated. Of these, 3,356 self-reported a positive and 602 a negative COVID-19 diagnosis (COVID+ and COVID-, respectively); 1,267 were awaiting test results (COVID?). The rest reported no respiratory illness and were grouped by symptoms: sudden smell/taste changes (STC, N=4,445), other symptoms excluding smell or taste loss (OthS, N=832), and no symptoms (NoS, N=416). Taste, smell, and oral irritation intensities and self-assessed abilities were rated on visual analog scales. Compared to the NoS group, COVID+ was associated with a 21% reduction in taste (95% Confidence Interval (CI): 15-28%), 47% in smell (95%-CI: 37-56%), and 17% in oral irritation (95%-CI: 10-25%) intensity. In all groups, perceived intensity of smell (r=0.84), taste (r=0.68), and oral irritation (r=0.37) was correlated. Our findings suggest most reports of taste dysfunction with COVID-19 were genuine and not due to misinterpreting smell loss as taste loss (i.e., a classical taste-flavor confusion). Assessing smell and taste intensity of household items is a promising, cost-effective screening tool that complements self-reports and helps to disentangle taste loss from smell loss. However, it does not replace standardized validated psychophysical tests.
nguyen_2023_preprint_medrxiv.pdf (1.93 Mo) Télécharger le fichier
Licence : CC BY NC ND - Paternité - Pas d'utilisation commerciale - Pas de modification
hal-04012100 , version 1 (02-03-2023)
Ha Nguyen, Javier Albayay, Richard Höchenberger, Surabhi Bhutani, Sanne Boesveldt, et al.. Covid-19 affects taste independently of smell: results from a combined chemosensory home test and online survey from a global cohort (N=10,953). 2023. ⟨hal-04012100⟩
21 Consultations
18 Téléchargements
