Importance of satisfying thermodynamic consistency in optoelectronic device simulations for high carrier densities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optical and Quantum Electronics Année : 2023
We show the importance of using a thermodynamically consistent flux discretization when describing drift-diffusion processes within light emitting diode simulations. Using the classical Scharfetter-Gummel scheme with Fermi-Dirac statistics is an example of such an inconsistent scheme. In this case, for an (In,Ga)N multi quantum well device, the Fermi levels show steep gradients on one side of the quantum wells which are not to be expected. This result originates from neglecting diffusion enhancement associated with Fermi-Dirac statistics in the numerical flux approximation. For a thermodynamically consistent scheme, such as the SEDAN scheme, the spikes in the Fermi levels disappear. We will show that thermodynamic inconsistency has far reaching implications on the current-voltage curves and recombination rates.
thermodynamical_cons_OQE.pdf (450.09 Ko) Télécharger le fichier
hal-04012467 , version 1 (02-03-2023)
hal-04012467 , version 2 (12-12-2023)
Patricio Farrell, Julien Moatti, Michael O'Donovan, Stefan Schulz, Thomas Koprucki. Importance of satisfying thermodynamic consistency in optoelectronic device simulations for high carrier densities. Optical and Quantum Electronics, 2023, 55 (11), pp.978. ⟨10.1007/s11082-023-05234-5⟩. ⟨hal-04012467v2⟩
80 Consultations
60 Téléchargements
