Good-case Early-Stopping Latency of Synchronous Byzantine Reliable Broadcast: The Deterministic Case (Extended Version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This paper considers the good-case latency of Byzantine Reliable Broadcast (BRB), i.e., the time taken by correct processes to deliver a message when the initial sender is correct. This time plays a crucial role in the performance of practical distributed systems. Although significant strides have been made in recent years on this question, progress has mainly focused on either asynchronous or randomized algorithms. By contrast, the good-case latency of deterministic synchronous BRB under a majority of Byzantine faults has been little studied. In particular, it was not known whether a goodcase latency below the worst-case bound of t + 1 rounds could be obtained. This work answers this open question positively and proposes a deterministic synchronous Byzantine reliable broadcast that achieves a good-case latency of max(2, t + 3 − c) rounds, where t is the upper bound on the number of Byzantine processes and c the number of effectively correct processes.
main.pdf (440.47 Ko) Télécharger le fichier
hal-04017887 , version 1 (07-03-2023)
hal-04017887 , version 2 (08-03-2023)
Timothé Albouy, Davide Frey, Michel Raynal, François Taïani. Good-case Early-Stopping Latency of Synchronous Byzantine Reliable Broadcast: The Deterministic Case (Extended Version). 2023. ⟨hal-04017887v2⟩
23 Consultations
33 Téléchargements
